does anyone use this card under linux? i have gentoo linux 2.4.20-gaming-r6 sources. i configured my kernel and installed v4l and bttv as modules, but i get an error everytime i try modprobe bttv:also, i do an 'lspci':Code:root@mymachine john # modprobe bttv /lib/modules/2.4.20-gaming-r6/kernel/drivers/media/video/bttv.o: init_module: No such device Hint: insmod errors can be caused by incorrect module parameters, including invalid IO or IRQ parameters. You may find more information in syslog or the output from dmesg /lib/modules/2.4.20-gaming-r6/kernel/drivers/media/video/bttv.o: insmod /lib/modules/2.4.20-gaming-r6/kernel/drivers/media/video/bttv.o failed /lib/modules/2.4.20-gaming-r6/kernel/drivers/media/video/bttv.o: insmod bttv failedam i installing the wrong driver? i would like to start using this card in linux since i cannot boot to winxp at the moment. thanksCode:02:08.0 Multimedia controller: Philips Semiconductors SAA7130 Video Broadcast Decoder (rev 01)
The bttv driver is for BT8x8 chipset based cards. According to ispci, your card is based on the SAA7130 chipset. I belive this chipset may be supported only in the newer v4l2 API. Take a look at the video4linux HQ SAA7130 page. Also make sure you read the build v4l2 drivers mini howto before you begin.am i installing the wrong driver? i would like to start using this card in linux since i cannot boot to winxp at the moment. thanksCode:
I have just bought one of these and I'm having similar problems. AverMedia told me directly some info: EZMaker (standard version) uses BT878 for which there are numerous modules/drivers available. EZMaker Gold (the version I have) uses the SA7130 Chipset (7134?). Everything I've read on the internet suggests that you need 2.4.23 Kernel and to update v4l2, apply patches and install a SA7134 module.
However - I've just done a fresh SuSE 8.2 install (2.4.21 I think) and the card seems to work on XawTV, etc. without need to recompile a new Kernel. I've no idea what is wrong because everything I've seen on the net so far says it shouldn't work. Can anyone tell me if I'm missing something here?
Error message with AverMedia DVD EZMaker
By JeffinPortland in forum Capturing and VCRReplies: 0Last Post: 16th Apr 2011, 17:26 -
HELP please Avermedia A316 Mini PCI-E Analog Digital DVB-T TV Card
By Jorocketoz in forum Capturing and VCRReplies: 0Last Post: 26th Jun 2010, 00:05 -
Unable to transfer some VHS to DVD using AverDVD EzMaker PCI Card
By fromvn in forum Newbie / General discussionsReplies: 4Last Post: 26th Oct 2008, 11:38 -
Cannot Uninstall or Reinstall UltraTV (AverMedia PCI 300 card)
By steve0701 in forum Capturing and VCRReplies: 2Last Post: 27th Mar 2008, 12:36 -
PCI/PCI Express 1x usb 2.0 card with 2 internal usb inputs
By SIRCOOKS in forum ComputerReplies: 0Last Post: 24th Jun 2007, 11:58
