just downloaded this to use with tmpgenc, when i browse to the location of file, the programme does not see it, i've renamed it to a .exe file, still no good, tia for any help to my 1st post....
It won't show up unless you alter the "files of type" option to "all execute file"
Environmental Settings > Audio Engine > MPEG Audio Layer II Encoder > External Program > Browse > Files Of Type > All Executable File. Should then show as Lame.exe.
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard. -
.gz files are g-zipped, like .zip files, only a different compression technique.
try downloading again, but not the gzip compressed file -
dkblade,
most decompressors today will unzip your .gz file. once that has been done you will have your desired file.
Is there a software or plugin?
By schematic2 in forum Newbie / General discussionsReplies: 4Last Post: 18th Mar 2011, 21:43 -
The Best Video Plugin Ever!!
By DemonSeed in forum Media Center PC / MediaCentersReplies: 20Last Post: 18th May 2009, 13:59 -
vegas plugin
By wingfan in forum EditingReplies: 5Last Post: 10th Nov 2008, 10:33 -
quicktime plugin
By geonuine in forum Video Streaming DownloadingReplies: 7Last Post: 17th Jul 2008, 20:38 -
tvseries Plugin for MediaPortal Help
By M.AD in forum Media Center PC / MediaCentersReplies: 0Last Post: 24th Nov 2007, 07:05
