Hi,
i have created 2 dvds using dvd author, putting 9 mpeg1 tracks on each. However on both occaisions, there is always a track that doesnt play if i choose it, it skips to the next track. The only way to get that track to play is to select it and the fast forward the first few seconds. Anyone know why this is or suggest another tool to use ? I think the mpeg1 file for that track is ok as it plays no problems in windows, problem only occurs when its included into the dvd.
Cheers
David
Results 1 to 1 of 1
Uknown DVD - Is First play track the problem (TMPGEnc Author Works 4)
By BobAchgill in forum Authoring (DVD)Replies: 4Last Post: 22nd Apr 2011, 07:26 -
TMPGEnc Dvd author 3 problem
By prcole18 in forum Authoring (DVD)Replies: 7Last Post: 7th Oct 2008, 12:33 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
TMPGEnc DVD Author 3 (MENU PROBLEM)
By jaffacaique in forum Authoring (DVD)Replies: 9Last Post: 18th Sep 2007, 20:43 -
Problems with TMPGEnc DVD Author 3 and multiple AVI files
By cadkins in forum Authoring (DVD)Replies: 6Last Post: 9th May 2007, 15:37
