Results 1 to 13 of 13
  1. The site is not officially launched, nor have we started our marketing campaigns, however, since we are such a great community here, I had to let you guys know early!
    It launches Jan 1st, 2004.
    www.afreeCodec.com , its a place where anyone can easily, within minutes, get the video or audio codec they need for there videos.
    We start our marketing campaigns in Jan.
    Any feedback on the site, such as requests, comments, and opinions will be taken into consideration! If you are interested in being a forum moderator for the site, you can also contact me at Jason@afreeCodec.com
    Thanks for reading this post, and most importantly, thanks for browsing our site!
    Jason
  2. Nice layout and easy navigation... A+ for that.
    However...
    the color scheme is a little drab, everything is a shade of grey. Try and add a little color.
    Also, I do not know if it came from your site, or an ad on your site, or wherever, but I got a pop-up. Consider not using them.
    "A beginning is the time for taking the most delicate care that the balances are correct."
    - Frank Herbert, Dune
  3. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    Where is Apple MPEG-4? I didn't see it on the list. Nor did I see pixlet on the list.
    I didn't get a pop-up.
  4. Awesome thanks for the feedback, I may try making the site available in 5 different colors for the visitor.... I was thinking...
    Green, Blue, Red, Grey, and Yellow/brown.
    And then the default colors will be grey How about that.
    (Unless another color will be better for default)
    There is also no popups on the site. This site will only conatin 1 banner located in the bottom left. I do not support popups.
    Hey tgpo, thanks, thats why we need fellas like you! To help our company provide the best service
    I would do the research but right now im extremely busy, if you wouldnt mind posting the last 2 codec sources. (Official download page)
    That would be great, else, i can always toss that on my todo
    Appreciate the input so far, Always glad to hear what the community wants. And I try my best to make them all satisfied.
    Looks good to me.
  6. Thanks!
    I have a good idea, since you dont need to be a member to post in my "Requests forum" and the other support areas...
    Would you guys mind posting any requests here...
    http://www.afreecodec.com/forum/forumdisplay.php?fid=3
    That would be great, it would also help get our forum content going because we offer 100% support.
    Any comments can be replied here...
    Thanks!
  7. Lost Will Hay's Avatar
    Oct 2002
    Buggleskelly Railway St.
    Great site !!!!!!
    Noticed a spelling mistake:
    If you are unsure what codec you need to get your video working. Please visit our "Codec Wizard" and fallow the easy steps!
    Good luck with the site.
    Will
    tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
  8. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    Apple MPEG-4 comes bundled with Quicktime 6
    Pixlet Information:
    Pixlet is the first studio-grade codec for filmmakers. Pixlet provides 20-25:1 compression, allowing a 75MB/sec series of frames to be delivered in a 3MB/sec movie, similar to DV data rates. Pixlet lets high-end digital film frames play in real time with any 1GHz G4 or better Panther Mac, without investing in costly, proprietary hardware.
    It comes bundled with Panther (OS X.3 on the Mac)
  9. opening ??
  10. Thanks
    I will be adding those 2 shortly. Grealy appreciated.
    Site opens Jan 1st, 2004.
  11. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    I didn't see:
    Sheer
    MS-MPEG4v1
    FFusion
    Included with Quicktime:
    Animation
    BMP
    Component Video
    Graphics
    Photo - JPEG
    PNG
    TGA
    Tiff
    Video
    Included with Final Cut Pro 4:
    Apple Uncompressed 10-bit 4:2:2
    Apple Uncompressed 8-bit 4:2:2
  12. Okay i have updated the video codec list, I also arranged them in ABC order.
    Tgpo, do you know the fourcc code for those you ahve announced? (See Video Codecs) that relate to those new entries? If not its alright it will eventually get on there. Appreciate the great help!
    Keep the requests coming
  13. Yes, I Know Roundabout's Avatar
    Jul 2003
    ...in and around the lake
    Great looking, well laid out site! Good job, Jason! Like the others, I too would like to see just a little color, though...not a criticism, just would be more pleasing to the eye, I think.
    BTW: There's a huge list of FourCC codes at http://kibus1.narod.ru/sof/abcavi/fourcc.htm
    along with downloads of the abcAVI program (it's freeware) that can be used to edit/change/browse AVI tags & FourCC codes, if that helps you at all. I recently got an AVI that uses FourCC of "COL1" that I looked up on that site, I noticed you don't have that particular one yet on yours, so you could use some codes from that list to add to yours.
    Download abcAVI here: http://kibus1.narod.ru/frames_eng.htm?sof/abcavi/index.htm (latest version 1.7.2.107 - 3 Nov. 2003)
    (BTW: Baldrick, it might be nice to add this prog. to the tools section of dvdrhelp.com)
    Info on abcAVI:
    abcAVI Tag Editor is little stand alone utility for viewing/editing tags in AVI files. In short it allows you to get information on movie from Internet Movie Database or type it by yourself and save that info inside AVI file. Supports RIFF INFO tags, MovieID tags, IDivX tags. Allows editing more then 40 tags, not only "Title", "Subject" and "Copyright". Support of RIFF INFO tags ensures backward compatibility with standart Windows players like MS Media Player.
    abcAVI Tag Editor shows complete information on AVI file both in tree style and in short form. It recognizes more then 650 FourCC and TwoCC codes (shows complete names of audio/video codecs used). Has predefined lists of contents for some tags (Product, Genre, Rated, Language, Source form and Medium). Allows multiple file editing - supports Drag-and-Drop files and directories to the main window (for example from "Find files" window), embeds its item to the MS Explorer context menu.
    abcAVI Tag Editor allows changing of FourCC video codec signatures, AVI frame rate (playback speed) and video frame size.
    abcAVI Tag Editor has Import function - getting information from Internet Movie Database. You can choose what to import (around 30 positions) and set the corresponding limitations. abcAVI sends all queries through e-mail interface and economize your bandwidth (only usefull information is getting from IMDb).
    abcAVI Tag Editor has flexible report creating system (Export function). You can create your own export templates using more then 150 predefined keywords (technical information on AVI file, AVI tags, etc). abcAVI supports TXT, HTML, XLS formats and other textual formats at your choice. As an additional function export system can rename AVI files.
    If anyone has some input/comments about this program I'd like to know your opinion. Thanks R.
    Ethernet (n): something used to catch the etherbunny
