Hello,
I wanted to burn a MPG file that I joined with a software program other than TMPGEnc..and Whenever I enter it in my DVD Authoring program, either it says that the header is incorrect or the video (31 mins) will only be 5 mins long..any help is appreciated. thanks
Hi ignignokt,
I'm no expert, but I've come across this myself and so hope to help a little (point you in the right direction hopefully).
I use TMPGEnc (I know you're not, but the principle must be the same) to encode DV AVI to MPG2 for DVD. On my first attempt, I had a headers problem and it turns out that each GOP (Group Of Pictures) needs something to identify it (sorry for the vagueness, but I don't know the detail).
I used the following guide:
http://dvd-hq.info/Compression.html
...Yes, I know it's for TMPGEnc, but it may help. In there, it refers to "Output interval of header" - I'm wondering if this is the cause of your problem.
Hope that helps...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
RESTREAM may help.
Thanks, but that didnt work either..im going to use VirtualDub to make it into an AVI and then try to re-encode in TMPGEnc....
Repairing mp4 headers manually.
By Wojo J in forum Newbie / General discussionsReplies: 6Last Post: 31st Dec 2011, 08:01 -
Problem with missing headers
By twentworth in forum DVD RippingReplies: 8Last Post: 22nd Jan 2011, 01:19 -
Access to the path 'F:\.mpg' is denied. Any idea how to fix it??
By StangGurl in forum Authoring (DVD)Replies: 6Last Post: 17th Dec 2010, 18:29 -
Sound on both channel fix possible on mpg and wmv?
By Blå_Mocka in forum AudioReplies: 2Last Post: 3rd Jul 2008, 14:25 -
how to fix broken mpg file?
By ecc in forum Video ConversionReplies: 4Last Post: 6th Oct 2007, 07:56
