I would like to know if it is possible to take jpg photos and convert them so I can play the photo album on a DVD player. Want to do it for family members. Thanks for the advice.
Take a look to the left under Author, scroll down to 'create VCD slide show.' The key thing is that the standard VCD resolution (352x240) sucks for this. However, the VCD standard supports stills at 704x480.
You can even add music if you want. -
But how can one get the high res picture.
I have a jpeg at 706x576 (PAL) and want to code it
to a MPEG-slide at the same resolution ?
Sofar all my tries end up with a low res mpeg.
Terry --
You had it right the first time.
When VCDTK generates an MPEG still, it creates a secondary low-res still and multiplexes the two together. Media Player only displays the low-res version, but the high-res version is there and will be displayed properly on a hardware player.
Thanks to Rfontenot for showing us the way.
Video like a JPG slideshow
By ranosb in forum Newbie / General discussionsReplies: 9Last Post: 11th Jul 2009, 18:38 -
JPG to AVI Back to JPG is it possible?
By concisa in forum Video ConversionReplies: 3Last Post: 11th Apr 2009, 10:06 -
jpg to mpg
By dona in forum Video ConversionReplies: 3Last Post: 9th Dec 2007, 14:45 -
Refresh jpg
By bendixG15 in forum TestReplies: 2Last Post: 16th Oct 2007, 05:30 -
Extracting jpg photos from the ITEM####.dat files in the VCD segment folder
By H-Man1953 in forum Newbie / General discussionsReplies: 5Last Post: 15th Aug 2007, 07:54
