I am a newbie... and looking for some assistance.
I was able to capture and have some video from my Sony TRV950 camera.
I tried to burn this to a DVD RW and play it in my Sony DVD player.
Here are some specs.
I used NeroDVD software
DVD writer is LG GSA-4040B
DVD media is Maxwell DVD-RAM RW
Sony DVD player is DVP-NS300
I burned the short movie using + and - format
the player searched the disk for some time, but never found it.
I burned the short movie as a VCD using a RW cd disks. This played fine in the DVD player.
I have some plain DVD disks Ritek brand. I don't want to waste these until I figure out the proper procedure.
Any suggestions?
Any place I find out what my DVD drive is compatible with? As far as + or - and media?
First of all I need some more information in order to help you . How and in what format did you capture the video . What program are you using to author the video . How did you burn it using nero , it needs to be DVD-VIDEO . I also noticed you listed a DVD-RAM disc . I dont think that your sony will play this type of disc .
Keep it on the big cam ! -
Your DVD player will play both DVD-R/RW and DVD+R/RW as can be seen here https://www.videohelp.com/dvdplayers.php?DVDname=DVP-NS300&Submit=Search&Search=Search
Your player will not play DVD-RAM. NeoDVD works well so that's not going to be any problem. So just take the DVD complient files NeoDVD makes (US NTSC I think) and put them into a VIDEO_TS folder then burn that folder and the disc should play just fine in your player.
Sony DVP-FX970 compatibility
By tigranmj in forum Latest Video NewsReplies: 7Last Post: 6th Apr 2012, 10:19 -
blu ray player firmware update removes media compatibility sony bdp-s300
By cdcutlip in forum DVD RippingReplies: 9Last Post: 8th May 2011, 02:03 -
Sony RDR-HX720 compatibility with Home Theater
By abdul_sma in forum DVD & Blu-ray RecordersReplies: 2Last Post: 13th Jan 2008, 22:44 -
Sony RDR-HX 720 compatibility with Onkyo HT-S990 7.1 Channel THX
By abdul_sma in forum DVD & Blu-ray RecordersReplies: 1Last Post: 9th Jan 2008, 03:55 -
dvd player with the best compatibility?
By JCWagener in forum DVD & Blu-ray PlayersReplies: 23Last Post: 16th Nov 2007, 21:17
