  1. Member golfnut's Avatar
    Sep 2003
    Need to buy new fans 4) for my computer case and was wondering what some of you would recommend. What is important to me with these fans is how quiet they are and the build quality and dependability. Thank you for your suggestions.
  2. I've always bought these ones. They're pretty quite and never had any problems with them.
    case fans
  3. The Nexus 80mm is currently recognised by the quiet pc crowd, as the best. 17.6 Db @ 20.2 CFM ..these are genuine stats. Not cheap though. http://www.nexustek.nl/80mmcasefan.htm
    Panaflo L1A’s would be a cheaper ‘quiet’ alternative.
  4. Member SLICK RICK's Avatar
    Mar 2003
    Houston, Tx by way of N.O
    I have 7 of these and my computer is extremely quiet.
    SLICK RICK
    Nobody likes a bunch of yackity-yack.
  5. Member golfnut's Avatar
    Sep 2003
    Thanks guys for the recommendations, I really appreciate your taking time to reply.
  6. contrarian rallynavvie's Avatar
    Minnesotan in Texas
    Visit www.sidewindercomputers.com for a lot of fans and cooling supplies. They also have a list of their fans as well as audio samples of what they sound like and a comparison of noise, airflow, and RPMs.
  7. Member golfnut's Avatar
    Sep 2003
    rallynavvie thanks for the address, great site they just need to update their listening room, last updated 1-02 and could not listen to the models I am interested in, non the less great site and thanks for the reply.
