Does anyone know whether the VirtualDub Dynamic Noise Reduction filter (v2.1) can be used more than once in the filter chain? If so, can it be run consecutively? Right now, I use these filters to clean up my SVHS captures:
DNR 2.1
2D Cleaner
CNR
Temporal Cleaner
but I think that if I were to add another consecutive instance of DNR, I could not only use lower values in each instance of DNR and still get the same or greater NR without the same level of artifacts, but I could reduce the strength of 2D Cleaner and Temporal Cleaner. Hell, maybe I could get a clean enough picture to do away with the dot-spray-dispensing Temporal Cleaner altogether and use something like temporal smoother at a low value (1 or 2).
Results 1 to 1 of 1
Graphedit filter chain with ac3 audio
By sambat in forum Video ConversionReplies: 3Last Post: 19th Jun 2011, 13:18 -
Is there a way to save a Virtualdub filter chain?
By groove365 in forum Capturing and VCRReplies: 5Last Post: 4th Sep 2010, 00:20 -
Multiple instances of tmpgenc?
By Bully9 in forum Video ConversionReplies: 1Last Post: 25th Aug 2008, 22:14 -
multiple instances of dshow being activated
By radman202 in forum Newbie / General discussionsReplies: 1Last Post: 29th Jan 2008, 10:50 -
Vdub Filter Chain
By christopheramos in forum Video ConversionReplies: 16Last Post: 3rd Sep 2007, 08:57
