Hi,
I'm trying to convert a AVI file into a DVD format however as soon as I try to load it it comes up can't load or unsuppported.
I believe i have the correct codec as the movie plays from PC no bother.
The following is cut from AVIcodec.
562 MB, 1472 Kbps, 25.0 fps, 480*335 (4:3), DIV3 = DivX v3MPEG-4 (Low-Motion),
Could anybody help??
thanks for the prompt reply.
i did read the problems page and could't find the answer to my problem.
I suspect it's the Codec but can't work out which one I need to download.
the following is cut from AVIcodec
562 MB, 1472 Kbps, 25.0 fps, 480*335 (4:3), DIV3 = DivX v3MPEG-4 (Low-Motion), Supported
Any ideas which one i require.
thanks -
Ok. I've tried to install Nimo Codec however it fails to load msvcr70.dll at the start.
any ideas am i getting warmer?? -
Did you try to change the priority setting like the guide said? You make no mention of it.
Hello. -
Kiss your video capabilities goodbye if you succeed! Your system might just have been saved by not having msvcr70.dll installed...
/Mats
Computer failing?
By dylz in forum ComputerReplies: 11Last Post: 13th Mar 2011, 04:08 -
MPC failing to load subtitles on long movies?
By crossmr in forum SubtitleReplies: 3Last Post: 26th Feb 2011, 09:27 -
Failing burner?
By Constant Gardener in forum DVD & Blu-ray WritersReplies: 2Last Post: 3rd May 2010, 12:57 -
is my cpu failing
By lordhutt in forum ComputerReplies: 12Last Post: 19th Dec 2009, 20:11 -
TMPGenc Xpress 4/VobSub cannot load .avi with subs
By varu in forum SubtitleReplies: 3Last Post: 14th May 2007, 18:26
