This is about DVD menu studio
I am really new to this so I have to ask, can I add a moving backround like for example I take a part from a movie were the name is
Example: Finding Nemo starts and the title shows then I take just that part and put it as a backround and makes it replay all the time. Does this work, if do then how do I do it.
DVD menu studio is more about creating the subpictures and still backgrounds.
You'll have to make sure that the authoring software you are using is capable of accepting motion menus. In the example of DVD-Lab, you would build the motion menu in DVD-Lab.
Pinnacle Studio - DVD menu with motion backround and thumbn.
By donpedro in forum User guidesReplies: 28Last Post: 28th Aug 2011, 12:51 -
Moving on from DV? What next?
By ron spencer in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 12th Oct 2009, 10:20 -
Moving to HD - need advice
By ZviT in forum ComputerReplies: 3Last Post: 3rd Jul 2009, 07:15 -
How create a custom Menu Backround when using convertxtodvd
By tealmarlin in forum Newbie / General discussionsReplies: 1Last Post: 24th May 2009, 15:49 -
Moving!
By Cornucopia in forum Off topicReplies: 17Last Post: 5th Jul 2007, 12:43
