What's the difference between 80m mode-1 and 80m mode-2 - if any?
Which one should I use?
karipuGuest
Mode 2 (form 2) has more room for data (2324 bytes per sector, 4500 sectors per minute) but it has no error correction, and must be used for VCD and SVCD (XA tracks).
Mode 1 has less room for data (2048 bytes per sector, 4500 sectors per minute) but has error correction and so should be used for DivX and any other data format intended for computer playback.
http://www.disctronics.co.uk/technology/cd-rom/cdrom_spec.htm
karipuGuest
Thank you for your response.
In this case; why in Quick Preset: SVCD, mode 80m mode-1 is automatically selected and not 80m mode-2?Mode 2 (form 2) has more room for data (2324 bytes per sector, 4500 sectors per minute) but it has no error correction, and must be used for VCD and SVCD (XA tracks).
karipuGuest
[quote]The media type is not set by Quick presets, but it could be a good idea to add auto-setting.
Yes it would (and add this information to your SVCD guide. ; )
Hi there,
Where is the setting to have ffmpegX output as mode 2 (when using SVCD preset)? The only option containing mode 2 I can see is in the bitrate calculator - is that the one? For some reason I thought everything in the bitrate calculator box had no effect on the encoding...
Thanks!
DVD Decrypter: File Mode total size double that of ISO read mode
By dare2be in forum DVD RippingReplies: 7Last Post: 13th Feb 2011, 13:21 -
JVC HR 9600....edit mode vs auto mode for digitizing s vhs or vhs
By fuzzblaster in forum Capturing and VCRReplies: 21Last Post: 21st Jan 2011, 09:28 -
Advantages of ripping in File mode over ISO mode...
By hiimbored in forum DVD RippingReplies: 9Last Post: 5th Jun 2008, 16:27 -
service mode?
By iThinkYouBrokeIt in forum DVB / IPTVReplies: 4Last Post: 28th Oct 2007, 00:35 -
VR mode to computer
By jeastman in forum DVD RippingReplies: 7Last Post: 2nd Sep 2007, 21:59
