Hey there......my apologies in advance for my newbie ignorance, but I'm attempting to convert some home movies from VHS to DVD, using my new Philips DVDR75. The Phillips receives my cable feed directly.
I've connected the video/audio OUT of the vcr to the front jacks of the dvd recorder. When I hit play on the vcr, I don't see an image, nor does the vcr image record on DVD. Both the vcr and dvd recorder are set to Channel 3. The only input the dvd recorder continues to receive is my cable signal. So. uh.........what basic step am I forgetting to do here?
I am using a standard black and white RCA plug that came with my dvd player to connect the two units. Even though there are input/outputs for 3 (red/yellow/white), the RCA plugs I am using only have two connectors (one for video, one for audio).......am I using the wrong kind of RCA plugs? As far as I know, colors don't really matter as long as you match them up.
Again, sorry for my ignorance. I'd appreciate any help.![]()
"First things first...........wiggle your big toe."
-The Bride, "Kill Bill Volume 1" -
Did you switch input (channel) on recorder to CAM 1 ?
Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
Aha! Yep, THAT was it. Took me a while to find how to switch inputs with the remote. The Philips manual isn't always the clearest, and I chanced upon it by mistake really.
Thanks! Transfer went great!"First things first...........wiggle your big toe."
Which camcorder (newbie question)
By CliveJ in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 32Last Post: 19th Aug 2011, 12:36 -
Should I Get An HD Camcorder? (Newbie)
By davebo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 18Last Post: 21st Jan 2011, 03:48 -
Newbie Needs Help: Searching for a camcorder
By RHMaxwell in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 11th Jan 2011, 09:32 -
Newbie here, which camcorder should i get?
By defectivelasagna in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 16th Aug 2009, 11:52 -
Newbie questions about HD camcorder etc!
By n33712 in forum Newbie / General discussionsReplies: 10Last Post: 4th Mar 2009, 14:16
