I bought a shiny new DVD unit. the box said DVD-R, DVD-RW, DVD-Video, Mp3, Jpg, VCD, SVCD.
So I burn a DVD-R full of mp3's, gleefully ready to play them.
No workee. This annoyed me very much. I sugest anybody in this predicament email their dvd player's tech support and demand a fix. You may use a copy of the email I sent to mine.
I have not included the brand of my DVD unit in a public post, until such time as I get a response from them. If they provide a firmware upgrade, i will be pleased.
CUT _____________ CUT
The manual says plays DVD-R, DVD-RW, MP3.... and other things. So I bought it. It will not play mp3's off DVD-R media. This is a very important feature, and the main reason I bought this player to replace my cheap old featureless player. Is there a firmware upgrade to fix this? If not I would like to exchange this model for one that will play mp3's on DVD-R media. The store I bought it from won't exchange (because technically it isn't faulty) it so it will have to be straight to you.
Thank you,
Your Name Here
CUT___________CUT
when u made the dvd was it a data dvd loaded with mp3's or did u actually make a mp3-dvd?
this might be ur problem, not sure though, another idea would be the media u used? good trustable media or junk?
hope this helps, josh -
Ordinary ISO data DVD. The media I use I burn movies onto without issues.
(Ritek G03 as reported by dvd decryptor)
There is no such thing as an "mp3-DVD" that i have ever heard of at least..... -
https://www.videohelp.com/glossary#DVD-MP3
DVD-MP3
This type of disc is created when MP3 audio files are burned on a DVDR/W disc. Very few MP3 capable standalone DVD players supports DVD-MP3 because most players verify DVDR/W as DVD-Video only -
umm, "DVD-MP3" is just a convenient designation for use on this website to denote DVD players with the capability duhmez is wanting. there is actually *NO* difference in burning, it *IS* just a bunch of mp3's on a DVD-ROM data disk. and yes duhmez, it is quite incredible that a *DVD* player will play mp3's on a CD-ROM and not a DVD-ROM
a lot of the cheaper players (APEX) will do this, but few of the *name* players - sony, panasonic, etc.
DVD+RW Wont Be Read
By WoH-George in forum DVD & Blu-ray RecordersReplies: 8Last Post: 26th Jun 2011, 14:28 -
can anyone help me figure out why certain files wont play on media player
By DaLoKi in forum Newbie / General discussionsReplies: 1Last Post: 13th Dec 2010, 15:44 -
.mvi clip wont play in Windows Media Player
By NP11073 in forum Newbie / General discussionsReplies: 0Last Post: 29th Nov 2008, 08:52 -
@^DVD-Roms wont Read Dual Layer^@
By Varchasve in forum Newbie / General discussionsReplies: 13Last Post: 20th Sep 2007, 20:13 -
Why wont windows media player play any audio from my created dvds
By thnkbg in forum Authoring (DVD)Replies: 1Last Post: 17th Aug 2007, 11:30
