Ok .... I need some music to add to my CD-R for new years and I'd like to capture what I'm listening to on one of the Winamp Music stations. It seems like it should be simple but maybe it's not possible?? No capture card in this system - but I can listen to the music all day long in Winamp. Is is possible to capture this music that is playing on my system?
"No freeman shall be debarred the use of arms." - THOMAS JEFFERSON .. 1776
If you have a wave editor you can record "What you hear" as long as you set up the recording source in windows volume control.
Go to Start...accessories....Entertainment...Volume Control.
Go to the options menu, select the radio button for recording and check the box for "What you hear"
Then set the recording level in the mixer. - Too loud and it will have nasty distortion.. too low and people will be able to hear themselves talk at your party. (play around with settings to get the right level)
The go to your wave editor (there are freeware ones available) and click the record button.
When finished you can convert it, split it to tracks, clean it up - whatever your heart desires. -
Thanks guys ....... great help here and I appreciate. Will try both before the day ends.
Winamp controls stuck
By solarblast in forum Software PlayingReplies: 0Last Post: 15th Jul 2011, 11:45 -
Winamp 5.571 weird phenomenon
By jyeh74 in forum Newbie / General discussionsReplies: 5Last Post: 27th Jan 2010, 17:54 -
Is it possible to capture a song's visualization from Winamp?
By hyphenate in forum Newbie / General discussionsReplies: 2Last Post: 31st Jul 2008, 19:30 -
Audio files now show as "Winamp Media File" in file type
By tmh in forum AudioReplies: 3Last Post: 7th Jan 2008, 14:25 -
Winamp issues
By jyeh74 in forum Newbie / General discussionsReplies: 22Last Post: 15th Oct 2007, 01:38
