Hi,
As the subject says ...
Thanks,
Sabesh.
Results 1 to 9 of 9
Most utilities tell you during the rip what speed they're going at, eg SmartRipper, DVD Decryptor.
if u want some really good info on ur dvd-rom then get a program called dvdinfopro, it rulez
josh -
Yeah, DVD Info pro tells you a lot about the drive but it doesn'ttell you how fast it will rip at. Says nothing at all about that for my LG 4040B...
I guess ripping-speed is about the same as read-speed, you can do a read-test with DVD Info pro and determine the rip/read-speed of the drive.
nero infotool, free, small gives you tons of info you can download it at:
http://www.cdspeed2000.com/go.php3?link=download.html -
download a ripping tool and rip a dvd. If your drive is locked it will stay between 2x-3x or less.
The LG 4040B built in September 2003 gives me a max rip speed of 7.6X but a maximum read speed of 12X. These were on non copy protected discs...
DVD Rom speed problem
By dafoe in forum DVD & Blu-ray WritersReplies: 8Last Post: 26th May 2010, 11:06 -
Replace dvd drive with dvd-rom drive.
By jtrapat1 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 25th Dec 2008, 10:33 -
New DVD ROM drive, works but PC warns on boot up
By LWC in forum ComputerReplies: 15Last Post: 24th Dec 2008, 17:19 -
Help on Choosing a DVD-Rom Drive
By scustalow in forum DVD RippingReplies: 1Last Post: 13th Jun 2007, 11:04 -
hd-dvd rom drive
By computerchuck in forum Software PlayingReplies: 6Last Post: 8th May 2007, 07:55
