Hi,
I recently purchased a Toshiba 4900 player, and have managed to hack into it and it is now region free. I'm just wondering since I have a NTSC tv, and in the DVD player booklet its laser type is listed as NTSC. Does this mean I cannot play a PAL disc on this player. Somone on the hack listings said it did PAL conversion, but didn't mention whether or not they had a PAL or multisystem tv. Basically, I just want to verify that this player will support PAL discs before I spend $20 to $30 on a region 2 DVD. If anybody can help, please post. Thanks!
Results 1 to 9 of 9
Just start exploring the menu on that DVD player. Look for an "output setting" or something. That is the only way to verify that it actually CONVERTS one format to the other.
I've seen some website that sell pre-hacked TOSHIBA DVD players that claim that not only are they REGION FREE but that they can also convert PAL to NTSC but the models I have seen in the past don't match up with the model you have but if it is a new model ... well I haven't been looking lately.
I didn't know one could hack into a TOSHIBA DVD player on their own. My understanding was that it needed a hardware hack but hey things change from model to model so ...
If you hacked it and made it REGION FREE and you have "heard" that your specific model does PAL to NTSC then it just might.
You probably won't know for sure until you try it. Would hurt you to buy just one PAL DVD to test. If it doesn't work you can always convert it to NTSC on the computer and burn yourself a NTSC DVD-R or DVD+R etc.
All Toshibas I've seen only play PAL VCD, not PAL DVD.
I've ordered a Region 2 PAL disc, so if this plays does that mean there is a built in converter or is it possible for a PAL disc to convert itself to NTSC. Thanks
Like I said I have seen some modified TOSHIBA DVD players that can do PAL to NTSC conversion but my understanding was that these were somehow modified with a hardware chip solution.Originally Posted by zippolight
So there is little way of knowing if your unit can do it until you try. Either it will work or it won't. If it doesn't work you will probably get some sort of scrambled most likely b/w image that will roll horizontally across the screen.
The Toshiba SD 4900 will play a Pal DVD and convert it to NTSC with a simple hack available on the left. Remote codes below:
Menu
1
clear
Marker
clear -
Plays PAL dvds perfectly right out of the box.
The remote hack worked, and so did the cd to make it permantly region free. Does perfect anamorphic PAL conversion as well (old players couldn' do both things at once).
I think almost all dvd players can do PAL conversion. They're just set to whatever tv type of the country they're being sold in.
Question about PAL quality on a USA DVD player and TV
By dancingcrab in forum Newbie / General discussionsReplies: 5Last Post: 10th Dec 2009, 13:39 -
Playing Region Free PAL DVD On Soon To Be Hacked Toshiba HD-A2 Player??
By akthmps in forum Newbie / General discussionsReplies: 5Last Post: 8th Apr 2009, 14:19 -
Philips DVP5990/37 and Toshiba XD-E500 NTSC to PAL question
By vatkat234 in forum DVD & Blu-ray PlayersReplies: 16Last Post: 19th Feb 2009, 10:12 -
Newbie, and considering hacking Toshiba HD-A2 to play PAL discs
By Puppets86 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 7th Jun 2008, 18:30 -
Toshiba D-R400 DVD Recorder - Is it PAL enabled?
By JEG in forum DVD & Blu-ray RecordersReplies: 2Last Post: 25th Aug 2007, 17:27
