When converting from an AVI clip for burning a VCD i have options for mpg (vcd file) and mpeg1,
what are the differences bet these two formats?
Could i use any one of them for burning a vcd which can be played back in a set-top DVD player? Should I get the same result when playing back?
Thank you!!
SLo
Use the MPG (VCD file option.) Although a VCD compliant MPG file is an MPG (and MPEG-1) file, the VCD specification requires a specific video bitrate (1150kbps) and resolution 352 x 240/288 (NTSC/PAL.) The MPEG-1 setting may not use these. Check your documentation for which settings the MPEG-1 settings uses, or give us more information, like the name of the program/hardware.
can i truncate mpeg1 video files without re-encoding?
By dullrazor in forum Newbie / General discussionsReplies: 2Last Post: 22nd Nov 2009, 16:47 -
Question how to join 4 mpeg1 files
By jimdagys in forum EditingReplies: 5Last Post: 28th Sep 2008, 22:18 -
any tool for converting vob files to mpeg1?
By sumeshkri in forum DVD RippingReplies: 8Last Post: 18th Feb 2008, 23:22 -
question about how to author DVD from several mpeg1 files
By jimdagys in forum Newbie / General discussionsReplies: 11Last Post: 5th Jan 2008, 08:49 -
Can't play MPEG1 video files!
By gummybear00 in forum Software PlayingReplies: 1Last Post: 27th Aug 2007, 01:04
