I downloaded and installed Autoshrinkiso 1.6 as well as DVD Decrypter and tried to get it working with DVD Shrink 3.0. Although I did exactly what is said in this guide (http://www.mrbass.org/dvdshrink/), everytime I start Autoshrinkiso I get the message that the DVD Shrink path is too long and that I have to copy it to a new file etc.
The strange thing is that ALL "my" paths are EXACTLY the same as in the given examples.
I also tried to copy the DVD Shrink exe file direct in C but with the same result. Even deleting and reinstalling Autoshrinkiso didn't help.
What else can I do to get it working ? DVD Shrink itself is working fine by the way. (For what it's worth, I use Windows XP)
Thanks in advance for any help.
Ton
Results 1 to 1 of 1
how do I install x264.exe to work AND to work with Lemings GUI?
By Krelmaneck in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2010, 22:13 -
Can't get it to work???
By rjocon in forum ffmpegX general discussionReplies: 1Last Post: 12th May 2009, 16:00 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 16:11 -
How much do you work? (work = doing something you are getting paid for)
By Baldrick in forum PollsReplies: 20Last Post: 26th Nov 2007, 15:35 -
How do they work?
By JamesGT in forum DVD & Blu-ray RecordersReplies: 2Last Post: 5th Nov 2007, 08:48
