I've just bought a Iomega Dual DVD writer. Downloaded the new firmware.
I would like to use the Nec Bin Patcher (available from http://www.herrie.org/ , has a lot of stuff from that site dissappeared since it moved?) to make the new firmware region free and remove the 2x rip restrictions.
This looks like it should be easy , but i need some help understanding exactly what each button does.
Has anyone else use this tool? If so can you explain how to use it correctly?
Results 1 to 1 of 1
Toss
Avchd patcher
By srfdude in forum Blu-ray RippingReplies: 4Last Post: 25th Feb 2010, 00:01 -
Where to download AVCHD-PATCHER 1.06? It has vanished?
By siratfus in forum Blu-ray RippingReplies: 5Last Post: 8th Jul 2009, 05:42 -
NEC DVD burners
By RapidRio in forum DVD & Blu-ray WritersReplies: 6Last Post: 6th Jul 2007, 21:07 -
NEC 4571A problem
By rmorrison1 in forum DVD & Blu-ray WritersReplies: 18Last Post: 1st Jul 2007, 12:35 -
NEC NDH81
By babagoi in forum DVD & Blu-ray RecordersReplies: 0Last Post: 24th Jun 2007, 19:05
