I've got an short intro video I would like to add to a DVD movie. I have the intro converted to DVD format but how do I add it to the movie so that the intro plays and then runs into the movie with no pauses??
Thanks!!!
If the DVD movie is on a DVD already:
Rip the movie, run it and the new clip through an authoring program like TMPGEN DVD Author or DVD-Lab have the intro connected to the beginning of the movie and reauthor and burn.
If the DVD movie is not yet on a DVD, skip the ripping part above and do everything else. -
I have two Video_TS folders, one is for the Intro and one is for the actual movie. How do I do that using TMPgenc DVD Author??
You can only have one VIDEO_TS folder. You need to Author the DVD starting with the intro clip and then adding the movie. TMPEnc DVD author seems to have trouble doing this but Moviefactory 2 and DVDLab make handy work of it. If you still have the MPG's just use one of these app's to Author, if you don't you might use TMPGEnc DVD Author to extract the MPG or Moviefactory 2 (I think) will read vob data.
Hope this helps
Is adding intro as simple as AVISynth?
By Aristocles in forum Authoring (DVD)Replies: 2Last Post: 16th Nov 2009, 01:19 -
Unskippable DVD Intro's
By mr. nawtynuff in forum Authoring (DVD)Replies: 18Last Post: 15th Oct 2009, 06:14 -
Dvd Intro help
By vcd4me in forum DVD RippingReplies: 3Last Post: 11th Dec 2008, 17:47 -
Short DVD intro?
By multiplex in forum Newbie / General discussionsReplies: 15Last Post: 6th Oct 2008, 12:45 -
Adding an Intro does not work in qdvdauthor
By mmasroorali in forum Authoring (DVD)Replies: 4Last Post: 15th Aug 2008, 09:31
