Hi there
I've had loads of problems with getting my DVD's to play on most home DVD players. I was using Nero 6, but because of previous advise I have scrapped Nero and I now have RecordNow v4.5.
I have created the DVD video files using Pinnacle Studio 8, which I also used to edit the movies.
How do I burn a DVD video using RecordNow? There doesn't appear to be an option to create a DVD Video, only Video CD.
Also, have you got any other tips on getting my DVD's to play on most home players?
Many thanks![]()
You select "Data Disc" in RecordNow Max. So put all the DVD files created by Studio8 (I'm surprised you got that far in that program) into a VIDEO_TS folder then burn that folder. Also be sure in options to select the discs option that closes or finalizes the discs otherwise it may not play in stand alone players.
Thanks very much, Bob W.
I did indeed have a lot of problems trying to get Studio 8 to create the files. I find it a great program for editing but rendering etc is useless.
While I'm here, what would you recommend as an alternative to Studio 8?
There is also some option .... Somethink like "make DVD compatible" ?!?!? That way it will check it first if everythink is OK.Originally Posted by Bob WPinnacle Studio 8 and DV home video editing (ver.9 already home)
wow... you better make sure you have "2" folders in there
VIDEO_TS
AUDIO_TS
there is nothing in the AUDIO_TS folder but some DVD players will not play the DVD without them, and make sure its all in CAPS, I had a friend that make coaster after coaster and finally relized he forgot to CAP the TS file folders.
If possible try to upgrade to recordnow DX 4.6, it might be free with 4.5, mine was.
Software to get home movies off DVD and Burn DVDs
By Angel835 in forum Newbie / General discussionsReplies: 6Last Post: 30th Jul 2011, 22:28 -
Ripping DVD Home Movies
By quxote in forum Newbie / General discussionsReplies: 4Last Post: 29th Jul 2009, 15:55 -
want to put home movies onto dvd
By shashgo in forum Newbie / General discussionsReplies: 2Last Post: 30th Apr 2009, 10:14 -
How to Burn Home Movies in BLUE RAY quality?
By ozab in forum Authoring (Blu-ray)Replies: 3Last Post: 15th Jan 2009, 10:52 -
Burn Home movies
By Tailgunner9 in forum Authoring (DVD)Replies: 5Last Post: 3rd Nov 2007, 13:26
