I used NTI CDMaker Platinum 6.5.0.33 and tried my first DVD+RW with my brand new GSA-4040B dvd recorder (the first I have)...
well, I wanted to make an UDF disc, but I screw things up and made some ISO/mode 1 DVD (I dont know what was created!!!), that burned only 2 GB and then a hardware error was reported...
Well, phisically the DVD media has no scratch, is clean, but I cannt finish the disc... Nero reports illegal medium when tried to full erase. If I ask to continue a multisession dvd, it found an open session, but can not close it... NTI CDMaker same thing...
I would like to know if anyone knows a software that FULL ERASE or WRITE to DVD media without listening ASPI errors... I want to revive the media or write over whatever is on it...
When I put the media in drive, WMP opens as it was an AUDIO media... and an error happens, of course...
BTW, there is no REAL hardware error... I can now make UDF media with B'Clips that came bundled with another media same brand...
Thanks in advance.
Fredİ[/b]
DVD Decrypter, right-click on drive--->Full-erase
You might get an error message, just ignore it.
If it wouldn't work, try again. -
Also Alcohol 120% has an option to Ignore Illegal TOC in erase mode.
This may help.
Tom -
thank you guys, for quick answer...
I will try them and post the results...
Fredİ -
Well,
no way with alcohol 120%... this error message appeard:
cannot write medium. Incompatible format.
I will try dvd-decripter...
BTW, Nero reports that the open session is MODE1 format...
Fredİ -
DVD Decrypter seemed to erase it ok... no error message, but I think it was only quick erasure, because it took less than one minute...
afterwards, B'Clips was able to identify media as a blank one, but when I asked it to format (Complete format), it started, then at 10% it found that UDF session formatted before and continued only logically formatting, no more phisical formatting...
near to end of formatting, another error appeard.
Finally, I decided to burn the media myself
with FIRE!!!
Thanks to all.
Fredİ
Convert DVD to AVCHD formatted disk?
By jntaylor63 in forum DVD RippingReplies: 1Last Post: 15th Dec 2009, 19:11 -
DVD-RW says it's formatted then says it's not!
By gjwireland in forum DVD & Blu-ray RecordersReplies: 0Last Post: 14th Oct 2009, 04:13 -
capturing of formatted dvd-rw?
By the1st in forum Capturing and VCRReplies: 4Last Post: 1st Jun 2008, 09:49 -
Looking for DVD player replacement - Good DVDR media support? (~£50)
By John_Jordan in forum DVD & Blu-ray PlayersReplies: 1Last Post: 18th Mar 2008, 15:12 -
How can I rip a badly made DVD?
By semmel in forum DVD RippingReplies: 6Last Post: 14th Jul 2007, 11:34
