i burnt a few dvd+r and dvd-r, and all of them play nice in my home dvd player. however when i put on label (those from cd stomper) and try to make them look nicer, all of them now cannot be read from my player. is it a problem of my player? how can i resolve this problem?
Must be your player so to check that out see if they will play in a friends player. I think if you soak the disc if warm clean dishwater for like an hour the label will come off.
This has worked for me many times.
If these are common paper lables.
Place on a paper towel and SOAK the surface with wd-40.
30 to 45 minutes later the label should easily lift off.
Wash disk in warm soapy water to get rid of wd-40.
Dry gently with a soft tissue.
All should be right with the world.
Hope this helps you out
kiki -
Hello,
The problem is the label, it retain the heat produced by laser and produce a dilatation of tracks, and the DVD-Player canīt compensate the read.
Remove tle label and you can read the DVD ok.
Wood
Putting paper labels on DVDs
By yznf in forum Newbie / General discussionsReplies: 10Last Post: 12th Feb 2012, 16:29 -
putting vobs to dvds
By chuchi327 in forum Authoring (DVD)Replies: 4Last Post: 23rd Oct 2009, 20:38 -
DVD Rom can burn DVDs but won't recognize burnt DVDs.
By soonie in forum DVD RippingReplies: 0Last Post: 23rd Aug 2009, 17:03 -
Printers for Putting a Label Directly on a DVD Surface
By solarblast in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2009, 21:04 -
Vista burnt dvds fail standalone playback
By bornmild in forum DVD RippingReplies: 3Last Post: 22nd Feb 2009, 18:02
