  1. under the System tab, should i set it to MPEG-2 Program (VBR) or MPEG-2 Super VideoCD (VBR)??
  2. i already looked thru that before and it's a useless SVCD guide. it's so brief that it doesn't go thru all the MPEG setting tabs. i'm also wondering if you can change where the cache is saved for multi pass VBR or is only for C drive? cuz i have way more space on my D drive. do i adjust the Temporary file>Folder setting>General tab>Environmental setting for the cache??
    Aug 2002
    Pittsburgh, PA, USA
    Well, if you are making and SVCD, I would use the Super Video CD setting.
    I set my temp folder to another drive, my Z drive.
  4. what's the diff btwn MPEG-2 Program (VBR) & MPEG-2 Super VideoCD (VBR)?
  5. Human j1d10t's Avatar
    Feb 2003
    California, USA
    They are different ways the audio/video files will be multiplexed together. MPEG2 Program is used for DVD, MPEG2 SVCD is used for SVCD.
    "Don't try to be a great man. Just be a man, and let history make its own judgment."
    Zefram Cochrane
    2073
