    Nov 2003
    SACRAMENTO, CA USA
    Need help!
    I use IfoEdit to removed the Warning notice and copied the same TEMP to another folder. When open DVD X COPY (advanced mode) the Browse radio button is grayed out. I want to make additional copies of the movie. How can I able to get the Browse option not to grayed out?
    Thank you.
  2. The browse feature is not enable in DVDXCOPY Platinum... It doesn't work.
