Which one is better?
Composite should work for you, then. Remember to get some good quality video and audio cables. They should be thicker than the cheaper thinner ones, but monster cables are considered overkill.
Hello. -
QUALITY: Coxial < Composite < S-Video < Component < Digital (e.g., Optical)Originally Posted by tony123
I thought component was digital. What does digital cable look like? And what is firewire?
Component video is still analog and even RGB or the 15 pin connectors (D-15 connector) are analog. A DVI input or output is all digital.Originally Posted by tony123
S-Video vs Composite for capture from S-VHS VCR
By HDClown in forum Capturing and VCRReplies: 5Last Post: 23rd Mar 2010, 08:23 -
VHS Capture - S-Video or Composite?
By Killer3737 in forum Capturing and VCRReplies: 21Last Post: 19th Apr 2009, 07:29 -
Capturing PS3 with composite
By Matryx in forum Capturing and VCRReplies: 0Last Post: 2nd Mar 2009, 18:13 -
Canopus AceDVio composite capture problem (Svid works, but not composite)
By bfrandse in forum Capturing and VCRReplies: 3Last Post: 28th Oct 2008, 11:55 -
Composite IN vs S-Video IN (using converter wire composite to s-video)
By goal in forum Capturing and VCRReplies: 2Last Post: 29th Mar 2008, 22:19
