I've owned a Pioneer DVR-A03 for about two years now. During that time I have had three instances where the drive wouldn’t read or burn certain media. I was always able to get the drive working again by cracking open the drive shooting it with compressed air and giving a thorough cleaning to the lens directly with a Q-tip and alcohol.
I just had to do this last night. I wasn’t able to burn some Memorex DVD-R 4x media. After giving the drive a cleaning, the drive worked fine.
Results 31 to 33 of 33
Should i do this "compressed air thing" through the tray...without to open the whole drive?
Unless you plan to clean the laser lens directly, I don't see much benefit of opening the drive just to give it a shot of compressed air.Originally Posted by Satanico Pandemonium
You could try the compressed air first. If that didn't work, then open the drive and clean the lens. If you plan to replace the drive anyway if it doesn't work, there is no harm in opening it. It isn't too hard to figure out how to open the drive to expose the lens, but you may want to search this or other sites to find instruction regarding how to open your specific drive.
What is a good DVD player lens cleaner?
By Puppets86 in forum DVD & Blu-ray PlayersReplies: 15Last Post: 26th Jun 2013, 20:35 -
Won't recognize disc
By totallylost1 in forum DVD & Blu-ray RecordersReplies: 7Last Post: 9th Jul 2011, 19:57 -
Computer won't recognize all my memory
By ricoman in forum ComputerReplies: 8Last Post: 1st Nov 2010, 17:28 -
Firewire External Enclosure for Sony DRU-500A. Help choose..
By donpedro in forum DVD & Blu-ray WritersReplies: 79Last Post: 25th May 2008, 12:52 -
Need advice on authoring a dvd lens cleaner disc
By JeffSVI in forum Authoring (DVD)Replies: 3Last Post: 7th Sep 2007, 10:09
