I have an XVID that is 25fps.
I realize that the original source would be PAL but is it not true to say that most rippers (including Smartripper) have the option to make it region free and therefor the 25fps could be in fact be region free?
If so,is there a software I can use that will tell me if indeed it is region free or still locked in as a region 2 ?
"Today is only yesterdays tomorrow"
Only dvds has regions. Region coding has nothing to do with the video.
Thanks Baldrick..
So, to be clear .
If I have a 25fps XVID then I can safely convert it to DVD without worrying about whether my region 1 player will play it?
(I realize that framrate conversion is a tricky thing...so I should leave it at 25fps???)
Thanks"Today is only yesterdays tomorrow" -
Thanks again Baldrick..
I know my player can play both Pal and Ntsc,but how can I tell if my TV does ?
(nothing in the specs indicate one way ot the other)"Today is only yesterdays tomorrow" -
Try it and find out, preferably using a DVDRW so as not to waste a disk if it doesn't. This assumes your DVD player will read them of course. Or you could make a PAL (S)VCD to try it.Originally Posted by wee haggis
I have played PAL vcd's ...
so does that mean that it will view Pal DVD's ?"Today is only yesterdays tomorrow" -
It should, though there are no 100% certainties in this gameOriginally Posted by wee haggis
Any way to determine is something was altered?
By droidgrl10 in forum Newbie / General discussionsReplies: 2Last Post: 19th Apr 2012, 09:49 -
How to determine if a mkv / avi / whatever file is constant or avg bitrate?
By smackyourfupa in forum Newbie / General discussionsReplies: 3Last Post: 8th Oct 2011, 06:26 -
Is there an easy way to determine the frame size of videos?(avi, mpg, etc)
By True Colors in forum Newbie / General discussionsReplies: 2Last Post: 17th Apr 2010, 16:45 -
determine which playlist to take
By KlintIstwood in forum Blu-ray RippingReplies: 2Last Post: 14th Apr 2009, 16:01 -
Determine best bitrate for a given resolution
By cd090580 in forum Newbie / General discussionsReplies: 7Last Post: 29th Oct 2008, 17:32
