why does tmpegnc only have function for 29 fps ntsc and not 23 ntsc when converting to dvd format.
is there anything i can do to compensate.
Load the NTSC template and then change to 23,976 with 3:2 pulldown.
Step 1,2 and Step 5:
on number 4 is this a constant figure i.e. the figure i should always use.
thank you for your help.
Replacement for TMPEGnc DVD Author for the Mac?
By The Monkees in forum MacReplies: 1Last Post: 24th Feb 2009, 14:36 -
AVI File Not Supported by TMPEGnc?
By The Monkees in forum Video ConversionReplies: 5Last Post: 3rd Feb 2008, 19:26
