From what i have read in the forum its possible to add sounds to a authoured DVD menu with either tmpgen plus or tmpgen authour how do i do it, it would be even better if i could get it to play a small wav/mp3 when a selection is made in the authoured menu!![]()
Not that I've seen. Unless I just missed something, that's not an option in TDA.
which authoring program is best then for creating menus with sound effects ????
DVDit! allows for sound menus
theres an option in tmpgen author that says "if a movie file has been selected as backgorund video of the menu, the audio of this movie file will be used as bgm" what exactly does this mean
When you create the menu, click on the background picture. An explorer box will open, browse for your mpg. This allows you to import a mpv/mpg stream. If the imported file has audio, it will be used for the BGM (Back Ground Music).Originally Posted by efiste2
You can still have TMPG generate the thumbnails and overlays as usual, only with your mpeg and audio playing in the background. I use Vegas, and/or Ulead Cool 3d to create the motion menus, and Smart sound for the BGMs.
BTW, if your tired of the plain yellow hot spots, you can use IFO Edit, and Menu Edit to change the color layout.
portable DVD player cracking sounds then hangs
By dzsoul in forum DVD & Blu-ray PlayersReplies: 5Last Post: 29th May 2009, 07:29 -
Is there a way to get all the ILife sounds on my PC?
By Nuke Shower in forum AudioReplies: 0Last Post: 16th Apr 2008, 16:30 -
DVD audio sounds high pitched
By nopulse in forum Newbie / General discussionsReplies: 3Last Post: 19th Nov 2007, 20:31 -
DVD to ipod sounds like a chipmunk no matter how I convert
By nukular in forum ffmpegX general discussionReplies: 3Last Post: 11th Sep 2007, 19:00 -
Sounds
By Gunny in forum Authoring (DVD)Replies: 2Last Post: 5th Jul 2007, 03:20
