currently i'm using 128kBps to squeeze out as much of the video bitrate as i can (i've read you shouldn't go lower), but i've also read to preserve Dolby Prologic information, a minimum of 192kbps is recommended. now i have no idea how to check if the source file has this particular information (anybody know how???), but is there really much of a difference that you can hear? i don't seem to hear anything different when i encoded at 224kBps vs 128kBps. maybe only if you're running a home theatre system? i just watch my VCDs on a regular tv set with it's own speakers.
I experimented a lot with this when I did make VCD's and I found that anything more than 128KBps was OK and was worthwile for extra capacity when making non standard VCD's i.e. fitting a whole 100 minutes video onto one CD . From my own experience I never noticed any deterioration in pro logic information (used the VCD with my normal Dolby Speaker System) at this bitrate , there still appeared to be the same extra surround information .
Ideal Size and Resolution HDTV for typical avi/mkv rips?
By Danteism in forum DVB / IPTVReplies: 3Last Post: 25th Nov 2011, 06:51 -
How much bandwidth is used in a typical 1 minute video?
By chrisj in forum Newbie / General discussionsReplies: 10Last Post: 13th Mar 2009, 14:37 -
Typical lifespan for a stand-alone DVD recorder.
By usually_quiet in forum DVD & Blu-ray RecordersReplies: 114Last Post: 27th Nov 2008, 21:21 -
Advice on how to downgrade the audio bitrate of a MOV file with AC-3 audio.
By InsanelyOne in forum MacReplies: 15Last Post: 13th May 2008, 22:40 -
typical newbie-No video but audio except gom
By nirbhayn in forum Newbie / General discussionsReplies: 3Last Post: 18th Apr 2008, 14:32
