  1. i read a lot of you guys using vcdeasy for that task, but has anyone tried doing it thru nero 6 (what i have) and if it's recommended/does the job sufficiently/simple to do? i have an entire concert that i want to burn and i'd like to create a menu, containing chapters of each song being performed, that'll show up on-screen when i put in the disc in my dvd player. and i'm also wondering if the 'next track' button on the remote would jump to the next song and pressing 'menu' or some other button will bring me back to the menu with all the chapters just like on a DVD?? i ask this cuz i've also some people reporting that when they pressed 'next track', it stopped play and brought them to the menu screen.
  2. What the buttons, etc. do during playback is programmable when you author the disc. When it comes to entry points (what you'd probably call chapters) and all this stuff I'd really recommend VCDEasy. I really don't know if Nero can do this or not.
  3. and do you insert the chapters or entry points to the video before or after encoding? any recommended newbie guide that i can follow?
  4. you "drop" your compliant stream (mpeg video) into vdceasy then you tell vcdeasy to insert chapter points, up to 99. quite easy really. This is done after encoding b4 burning (use cdrw till you get it right).
