Hello,my friend lent me a film called gangs of new york to do a copy of.The film is on 2 cd's and i want to put it onto 1 dvd-r.I know how to convert to .avi and then to mpeg 2,the question is is that when i drag the 2 mpeg 2 files into tmpgenc dvd author is there a way of putting the 2 files together so there isnt a break or will it not matter as the film will just run normally without being able to see the break when watching the finished dvd-r?
I hope you can understand what i am trying to say,i have checked the guides and it just says you can drag one or more films into the author program but dosent say anything about making a 2 disc film into 1.
Thanks in advance.
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator Craig Tucker
Closed Thread
This is what I would do:
1. Use Virtualdub to open "Gangs of NY #1"
2. Under "File", select "Append AVI Segment" and select "Gangs of NY #2"
3. Under "Video", select "Direct Stream Copy"
4. Save the AVI
Hope this helps.[/list]
Film capture issue - partial film frames on a video frame. Why?
By brassplyer in forum RestorationReplies: 14Last Post: 27th Apr 2010, 17:14 -
The Independent Film Channel - efficient film challenge - cash prizes
By minidv2dvd in forum Latest Video NewsReplies: 1Last Post: 23rd Oct 2009, 10:44 -
Telecine Machine for 8mm film super 8 film transfer to dvd
By igotregister in forum Capturing and VCRReplies: 5Last Post: 2nd Feb 2009, 16:50 -
Where's the other half of my film?
By headless chicken in forum MacReplies: 0Last Post: 6th Jul 2007, 21:04 -
My DVD Film backups are 'freezing up' near end of Film
By Artom in forum Newbie / General discussionsReplies: 5Last Post: 18th Jun 2007, 04:01
