I have been trying to convert DVD to SVCD using CCE 2.5 doing 4 passes. It takes around 25 hours to convert a 2 hour movie! I have a P3 with 640mb RAM. As you can see that is very slow.
Will two passes be quicker. Will this halve the time? I do not have a problem with coding around 12 hours so I can leave it overnight and do other things in the morning.
How much time difference is there between 2, 3, 4, and 5 passes. Does each pass takes the same time as the first pass (Say one pass take 8 hours, two 16, three 24 hours and so on)?
Let's face it 25 hours your are wasting a lot of resources, you might as well buy another DVD disk to back up and probably it will be cheaper.
Other thing I would like to know is that if there is a significant difference in quality betweent the different passes?
Thanking you in advance.
"Seek you will find it"
Yes, each pass takes as long as the first. Don't forget that CCE first makes a CBR pass to create the VAF file, so 3pass VBR = 4 passes. I normally use 3pass VBR for DVD rips and get excellent quaility.
2pass or 1pass (1pass VBR in CCE = 2pass VBR in TMPGenc) would save a lot of time, how much of a quaility hit you'll take depends on your eye, and the bitrate.
For encodes where the bitrate is 2200 or greater I just use CBR. Some use CBR at 1800+, but I can see the dither in high motion scences.
time difference between audio and video after capture till tens of seconds
By dekelbeitar in forum Capturing and VCRReplies: 0Last Post: 7th May 2009, 10:11 -
CCE SP2 number of VBR passes
By DRP in forum Video ConversionReplies: 1Last Post: 25th Oct 2008, 02:53 -
HD-SD Time Difference?
By Nelson37 in forum Newbie / General discussionsReplies: 0Last Post: 9th Sep 2008, 20:13 -
Time difference between VOB and MPEG
By sambat in forum Newbie / General discussionsReplies: 6Last Post: 18th Aug 2008, 15:06 -
vbr passes in cce 2.70 sp
By DSLGuy in forum Video ConversionReplies: 1Last Post: 19th Feb 2008, 23:33
