I will be videotaping a dance recital on the 20th. I plan to record to the 510 via the firewire out from camcorder. I will record to the HDD in fine mode. I am also going to record to the E50 via an S cable from the same camcorder. I will record in XP mode. I will have identical footage to compare quality. I'll post results
Only problem I can forsee, is by using XP mode on the 50, I will run out of space after 1 hour, whereas the 510 will record for 17 hours in fine mode
Results 1 to 1 of 1
Is there a small test video one can use to test Rec 601 / 709 conversion?
By Asterra in forum Video ConversionReplies: 5Last Post: 19th Jun 2011, 09:28 -
[b][url]TEST! TEST TEST! WHAT"S THE BEST?!!!!!!!111111
By lordsmurf in forum TestReplies: 0Last Post: 2nd Aug 2010, 03:30 -
1080p true hd to 720p true hd possible ?
By miss in forum Video ConversionReplies: 2Last Post: 16th Jul 2009, 22:48 -
Pioneer 510-H Won't Power Up
By groberson in forum DVD & Blu-ray RecordersReplies: 2Last Post: 21st May 2009, 01:11 -
Sony RDR HX 510 and DVP NS 305
By SearchQuality in forum MediaReplies: 10Last Post: 16th Nov 2007, 11:41
