Hey, I'm new to this stuff, so bare with me
I tried burning a movie an svcd on TMPGEnc, but when played on the dvd, the colors had lost alott of it's sharpness and clarity.
I guess it'c douce it's a bigger screen then on the comp, but is there any way to get aroundt this?
Would really appreciate help![]()
You can increase the bit rate, so it can increase the quality a little. Or, you can burn the movie as a DVD, if possible.
Hello. -
so how much should i increase it with?
don'tthink i can burn it as a dvd.
how do you do that?
what i know, you can only use vcd and svcd on my program -
You use the wizard, and when you get to screen 4/5 adjust the bit rate as high as it will go while still fitting on a single CD. This will create a XSVCD, some DVD players can play it, others can't. Try encoding a 5 minute sample or so, and see if it works for you.
Hello. -
how do I check that?
I mean that would mean I would use an entire cd just to check it it woul work right?
couce one can't erase what you oncemade right? -
Someone should have told you: Use CD-RWs if you are just starting out. These you can reuse as often as you like. To make a sample video, follow the wizard steps as before, but when you get to screen 3/5, double click on source range.
When the source range window comes up, move the slider until about five minutes is displayed in the upper left part of the display. Select Set end frame, to mark the end of the video you wish to encode. Select OK. This will encode only the first five minutes of your video. Proceed as before.Hello. -
yeah knew about the source thing, didn't really know about RW styff though, heh I kinda thought if you've seen one print cd you've seen them all ^_^
oh well looks like i'm gonna have to go out and by me a set of CD-RW's
thanks alott for the help
oh maybe i should ask
what is a good resolution?
on the cd i first tried and the color went bad some of the subtitle (it's in japanese) didn't show.
could you reccomend a size that's good?
Does up-converting loose clarity?
By CrackBookPro in forum Video ConversionReplies: 2Last Post: 19th Aug 2010, 17:58 -
How to email video without losing clarity
By Tiger2 in forum Video ConversionReplies: 9Last Post: 28th Feb 2010, 08:01 -
Video Clarity Issues
By belarefon in forum Newbie / General discussionsReplies: 14Last Post: 24th Nov 2009, 08:53 -
Sharpness in GK
By eliqush in forum EditingReplies: 9Last Post: 4th Aug 2009, 09:54 -
Will the slideshow reduce the picture clarity and why?
By coody in forum Authoring (DVD)Replies: 2Last Post: 1st Oct 2008, 22:44
