I'm learning VB and have found some adverse effects. It's led me to think about something.
If someone wrote a very small program that McAfee or Norton has never seen before, and we'll say this program has malicious code, will either of the Virus Scanners detect that its a viral program?
That is to say, if a new program was created and somehow had a line of code to delete everything in your windows folder.
Script kiddies do that all the time. After a number of people are hit and submit reports to the security people they scan for the code, test it, and write a definition and maybe removal tool. I do believe Norton will report on its own, but not sure.
There is a chance Norton and McAfee will catch what "appears to be a virus", but since it hasn't the actual definition in its data base, may offer to quarantine it. Let it.
Went to Win Update, today,as MS has said it is pulling the plug on 98, as of Jan 16. It wouldn't update, said none available.
Guess I'm going to W2k for my Primary OS. openware.org seems to still be writing security patches.
Cheers,
George
Video is blurry on computer but clear on HDTV, how can it happen?
By Bencuri in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 55Last Post: 26th May 2012, 11:48 -
what would you do if this happen to you?
By Webster in forum Off topicReplies: 8Last Post: 6th May 2011, 12:23 -
Why does this happen? Resolution problem.
By bananadude in forum EditingReplies: 8Last Post: 14th Jun 2008, 02:47 -
----jerky motion----when did that happen?----
By ozne64 in forum Video ConversionReplies: 6Last Post: 15th Jan 2008, 05:00 -
What will happen to analog cable after the digital switch???
By yoda313 in forum Off topicReplies: 5Last Post: 12th Jun 2007, 18:32
