Is't possible to do it?
That I want to do is using mine X-Men 2 DVD and use the menu for a xvid movie. (of course after encoded it to mpeg2 file and ac3 sound).
If it's possible? Are there any guide for how to do it?
Vobrator will demux the menu vob by cell id leaving you with m2v, ac3 and sup files.
If it's a still menu, load the menu vob into DVD2AVI change the color to rgb, scroll to the frame, and export as a bitmap.
Play the menu with your software player, and export a screen shot.
Load the menu Vob into MPGVCR and trim/cut where you want, or export a still.
How to extract/edit subtitles from DVD
By pincrete in forum Newbie / General discussionsReplies: 2Last Post: 15th May 2011, 12:19 -
Edit, add, extract WAVE and edit file tags with new Machete 3.5
By MacheteSoft in forum Latest Video NewsReplies: 0Last Post: 23rd Dec 2009, 11:05 -
EDIT/EXTRACT from one of my commercial DVDS to make a custom-stitched DVD?
By MISS CHIEVOUS in forum Newbie / General discussionsReplies: 10Last Post: 12th Aug 2009, 16:04 -
Extract DVD to edit in Vegas Video
By kmxe in forum Newbie / General discussionsReplies: 7Last Post: 29th Apr 2009, 09:26 -
extract dvd menu text & time
By msdiane in forum Newbie / General discussionsReplies: 0Last Post: 26th Oct 2008, 12:25
