Hello there - can someone please help?
My former setup was this:
Athlon T-bird 900 with 133FSB
on an Abit K7 (not raid)
I have two HD's,
8GB Maxtor 5400rpm
20GB Western Digital 5400rpm
512MB PC133 ram
ATI RAGE FURY PRO 16MB (for capture and all)
Soundblaster16 ISA
I was able to capture at 740x480 with the PICVIDEO Mjpeg codec no problem. I don't recall losing a frame at all.
Now I've upgraded the MB, Processor,soundcard and Vidcard to the following:
Athlon T-bird 1Gig with 266 FSB
on an ASUS A7V133
and an ATI Radeon DDR 64MB
Ensoniq PCI
all other stuff is the same - same HD's etc
I was told a while back that the ISA card was a bit of a bottleneck - but anyhow - now I have all this new stuff - and I figured it would whoop ass compared to what I had, but to my dismay, Virtual Dub DROPS FRAMES LIKE MAD! At 740x480, the CPU usage is only at around 28-30%, where it used to be around 40-50% - but i'm dropping frames like crazy. I have DMA enabled (mode2 on one drive, mode 4 on the other) - i have just defragged everything.
Is there something i could be missing?
Maybe a BIOS setting?
Please help. OH By the way - when i say dropping frames like MAD - how is 209frames in 9 seconds?
Thanks - MOLE
<font size=-1>[ This Message was edited by: mole on 2001-10-14 20:05:54 ]</font>
Results 1 to 13 of 13
I agree that ATI may have some issues - but i refuse to believe that's the problem - my old ATI was off to a shaky start - it needed some tweaking - but it worked out after all.
Besides - why would an older card work better than a newer one with twice the memory? -
woops - posted twice
<font size=-1>[ This Message was edited by: mole on 2001-10-14 22:00:47 ]</font> -
my gosh jeex, how could you even post that last note on the web? aren't you ashamed of yourself?
Hey mole what capture prog you use..I sure would like to figure how to get that high resolution without dropping frames...t
I usually use Virtual Dub to capture
like i said - with my old RAGE FURY PRO it captured fine... -
Just making another post so this will show up on the main page - anybody have any ideas? Sefy? Baldrick? Anyone?
COOL! I got it! I just updated the driver to the latest XP driver, instead of the win2k driver!
The driver that comes with the XP CD didn't work, and i didn't see the other "official" driver before - yes! Now i can even capture PICVideo at 20 quality - where before i could only capture at 19
now i don't lose a frame at all... sweet.
I had a problem with my system and I was trying to overclock my system, anyway I left my pci delay to DISABLE and it should of been ENABLED. Hope something like this helps.
I have the same set up as you and I am haveing a simalar problem where did you get the Driver and are you using Windows XP
yep - i'm using XP - i just got the driver at http://www.atitech.com in the downloads section - it cleared everything up
depending on your MOBO bios you will need to "Load the Optimized Defaults". Mine didn't have the optimized ones loaded-dropped many frames until that. Now 0 dropped. And I only have an Athlon 650mhz
Why does your system drop frames?
By txpharoah in forum Capturing and VCRReplies: 118Last Post: 12th Aug 2023, 16:13 -
why does Flash video drop so many frames ?
By davexnet in forum Video Streaming DownloadingReplies: 19Last Post: 1st Oct 2013, 08:04 -
drop half of the frames without reencoding
By mathmax in forum Video ConversionReplies: 4Last Post: 11th Apr 2012, 17:39 -
Does current ADStech Pyro (firewire) w/Premiere still drop lots of frames?
By miamicanes in forum Capturing and VCRReplies: 9Last Post: 20th Sep 2007, 00:41 -
How to backup sytem/hhd using Acronis True Image 10?
By evol ecallaw in forum ComputerReplies: 5Last Post: 1st Jul 2007, 03:03
