I would like to create a menu that links to several different movie files (actually analog caps of short VHS kids movies). It is easy to create a scene select type of menu that links to each clip, but I also want a "Play All" button that starts at the first movie and runs through the others in series. The only way I know to do this is to link each movie to the start of the next one, but that messes things up a bit, because now if I select "Movie #2," at the end of "Movie #2" it will go to "Movie #3" and through the rest of them, and I would rather have it go back to the menu after "Movie #2" has finished.
Is there a way to make conditional statements that allow me to string these movies together ONLY if the "Play All" option was selected??
Thanks,
Stuart
What I would do is merge all the movies together into one file, load that file into DVD-Lab and add chapter points at the beginning of each new episode & make each link point to a chapter point....
"Hello. My name is Inigo Montoya. You killed my father. Prepare to die." -
At this point in time, I think that you are stuck with what you have. However, I noticed on the DVD-Lab website, that 1.4 beta 2 will have a scripting language, which will allow you to do a lot of things you couldn't before, one of them being a functional play all, and then being able to go back to the sub menu you launched from.
You didn't look at the guides section on this site then ?
How to program a PLAY ALL button for DVD Lab
dvd lab pro movie numbers regularise
By sumeshkri in forum Newbie / General discussionsReplies: 1Last Post: 24th Oct 2010, 01:28 -
How to select audio track opening multi-track container in avisynth?
By lovyagin in forum Video ConversionReplies: 7Last Post: 23rd Sep 2009, 12:16 -
Can i actualy preview the subs in the movie in DVD Lab ?
By mordor in forum SubtitleReplies: 0Last Post: 22nd Mar 2008, 09:02 -
DVD Lab Pro - Movie clips in menu
By flipzoso in forum Authoring (DVD)Replies: 1Last Post: 26th Oct 2007, 02:38 -
multi menus (in DVD LAB PRO 2) with different formats/Button issues
By dblue in forum Newbie / General discussionsReplies: 11Last Post: 18th Oct 2007, 18:10
