Hello,
Can anyone tell me how I can strip out just the audio from something I recorded on DVD and then convert the audio file to a format to allow it to be played on CD? Also, once you do this is there a way to cut up the audio file to make individual CD tracks? I would like to try and do this with the least expensive amount of software required. Any help would be appreciated.
Thanks.
There are many ways but the easiest way is to use DVDDecrypter (IFO mode->Stream Processing->Demux) then use AC3Tool or BeSweet to convert AC3 to WAV.If the audio is DTS forget it,if the audio is MP2 then use TMPGEnc to output to WAVE.
Then use www.cdwave.com to downsample to 44.1khz and split into tracks.
All the tools I mentioned are free but you might try Goldwave($40USD) because it can do all of the above. -
Can Goldwave do everything including the stuff covered by DVD Decrypter and is Goldwave pretty user friendly? Thanks for the help.
Tom -
Having never tried to attempt anything like this, I was just wondering if the software was easy to follow.
Thanks,
Tom
How to remove one of two audio tracks in a mkv file?
By BooSnow in forum AudioReplies: 4Last Post: 18th Oct 2020, 10:00 -
How do i remove an audio track from an AVI file?
By alih786 in forum AudioReplies: 51Last Post: 29th Nov 2016, 06:31 -
How we can increase audio of a video file when we burn it on dvd
By nusratjaveid in forum DVD RippingReplies: 2Last Post: 5th Dec 2010, 22:35 -
No Audio On AVCHD-DVD, How To Remove Other Audio Tracks From MKV File First
By elistian in forum Video ConversionReplies: 1Last Post: 14th Dec 2009, 06:03 -
How to remove noise in audio of mkv file
By maass in forum AudioReplies: 1Last Post: 11th Nov 2008, 03:08
