Basic Question:
Can I transfer a video from my PC to VCR by using the TV out on the Graphics card, or are there any hidden problems here.
I only have the Canopus ADVC-50 which doesn't have output to VCR capability.
Cole
The only way to figure out if you can transfer a video from your PC to your VCR is to hook things up and try,install software, try,reboot, try, change settings, try again and if everything else fails ... take a beer and try again.
About the hidden problems, [yoda mode on]there will be, there will be[/yoda mode off] -
Should be able to but you might have to resize the output image. Check the www of your VGA card for any guides.
Regards,
Rob -
Macrovision!
You can't play a DVD on your computer and record it on your VCR. Macrovision is required on all new Video cards. Although it can be disabled......To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Thanks for all the help.
Where I can make VCDs to give to people, there are still a few of my friends who don't have DVD players (or have a DVD player that won't even play CD-R audio!!!)
What I want to do is to transfer a couple of MPEG files to VCR but opted for the Canopus ADVC-50. Macrovision shouldn't be a problem here as the file is already created.
I will give it a go and see what happens.
P.S. Sark, I hate beer, I'll have a Cider!
Cole -
@Cole,
Any drink with a little alcohol
in it will do, stay away of the coffee
... you don't want to get psyched up.
Good luck
VCR/VHS playback - lines on picture...vcr alignment problem or no?
By daysaf00 in forum Capturing and VCRReplies: 1Last Post: 23rd Jan 2012, 01:54 -
VCR help Plus
By goldberg317 in forum Newbie / General discussionsReplies: 1Last Post: 23rd Dec 2008, 10:14 -
Best VCR...
By Superstar24 in forum Newbie / General discussionsReplies: 9Last Post: 20th Dec 2008, 00:28 -
Do you still have a vcr?
By yoda313 in forum PollsReplies: 52Last Post: 25th Nov 2008, 22:37 -
Best VCR OR VCR/DVD COMBO for restoration
By demonwarrior in forum Newbie / General discussionsReplies: 7Last Post: 24th Aug 2007, 03:02
