I wonder if anyone knows of DVD authoring package which would allow me to fade out at the end of a chapter and fade in the beginning of the next -visually that is? I currently use Virtualdub and TMPGenc - both of which do not appear to offer this option.
Cheers
That is the kind of feature you would find in a video editing program. It is not something I would expect to see in an authoring program.
THanks I'm a bit new at all this and some of the terminology (ie authoring, editing kinda mean the same thing even although I've done a lot of reading).
Any editing package you can recommend?
Cheers -
Well, I use Premiere, but its not cheap and probably overkill for simple fades. Some one else can probably reccomed a decent but cheaper package.Originally Posted by bigeck
avisynth - how to fade in (but audio has to fade in faster)
By adom in forum EditingReplies: 13Last Post: 31st Jan 2011, 13:45 -
Fade in Fade Out CD Music Software
By mn072065 in forum ComputerReplies: 0Last Post: 6th May 2008, 09:23 -
Fade in Transition Fade out scenes
By ancient in forum Authoring (DVD)Replies: 4Last Post: 30th Nov 2007, 06:04 -
fade in/fade out with smart rendering
By bmf in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 10th Jun 2007, 14:33 -
Fade-in\Fade-out filter, VirtualDub MOD
By GangstaRap in forum Video ConversionReplies: 3Last Post: 21st May 2007, 21:58
