Just looking for an opinion.
I'm looking at a 120GB 7200rpm SATA drive (8MB) cache.
I have three IDE 8GB hard drives currently.
I believe the HD is my bottleneck -- I'm just wondering how much encoding speed I'll garner from relieving this bottleneck.
Don't need absolute times -- guesses of percentages is plenty.
"Risk... is our business."
8gb...Are they even 5400RPM?
I bet you will shed a lot of encoding time off just buy getting a IDE 7200rpm drive. Serial is even better if you have a serial ATA controller. -
Actually, the speed of the HD has VERY little impact on the encoding time. The extra space will be a bonus though
Yep, the bottleneck for encoding is CPU power in almost all cases. However, you would get better capture performance if you need it by getting a new hard drive. But, judging by the fact you only have 8Gig drives, you probably capture straight to mpeg anyway. In that case it doesn't matter much.
"A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune
Field Order
By Tafflad in forum Authoring (DVD)Replies: 9Last Post: 30th Jan 2010, 01:38 -
out off order chapters
By vadded in forum Newbie / General discussionsReplies: 2Last Post: 16th Dec 2009, 13:11 -
Chapters out of order
By briandugas in forum DVD RippingReplies: 4Last Post: 27th Oct 2009, 13:57 -
DV - Frames out of order
By devonuto in forum EditingReplies: 3Last Post: 25th Jan 2008, 02:45 -
Field order?
By miamicanes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Sep 2007, 17:14
