How many of ya'll love LiveType as much as me? I've used it to make a number of DVD Menus and it works / looks wonderful. If anyone doesn't have it I highly recommend picking it up.
I most recently did a DVD for all my movies. I'll post a short movie of what the scenes look like a little later.
Results 1 to 15 of 15
Here is an example of the scene selection menu I did in LiveType.
Ok,
so I thought LiveType was for creating spinning, bouncing logos on DVDS?
Can you also create picture bar drop zones ( which I assume that is what
is on the pict you posted)? or do you use DVDSP2?
And speaking of DVDSP2, I want to make a custom DVD project,
that enables me to create an opening splash like the DVD for John Q
( left side large drop zone , bottom to right bottom custom drop zone,
both containing clips of movies) and above the actual menu buttons.
Can you custom make Drop Zones in DVDSP2?
Modifying IDVD 3's drop zones was a hassle and I could never get them to act right. -
Using DVDSP 1.5 I made each of those rectangles a button that linked to it's video. LiveType was used to actually create that video. I'll work on a short guide to let everyone see how easy it is to create motion menus using these two programs. I saw on another website where they were charging $30 for steps to to that, and I'll give it for free
And for this, and the upcoming DVDSP2 tutorial,Originally Posted by tgpo
You will forever have my eternal gratitude and have built
many good works by which you shall earn your place in
nirvana! -
We finally got DVDSP2 here at work. So I can now get some screenshots for the guide until I get my computer fixed.
that's pretty neat.
does anyone know of a repository of free templates and other objects for DVDSP created by the community? maybe we should start one ... -
I've looked around and there isn't any. If we wanted one, we would have to do it ourselves. Which sounds like fun to me
hey tgpo, thanks for offering up those templates at your website!
one problem though -- I can't 'see' them in DVDSP2.03 -- I followed the included instructions, I've also tried using the import template option, but I just don't know where they do and how I can select them!
thanks if you can help me with this ....... -
WHen you click on Templates are you only looking at the Apple ones? Are none listed under Custom?
Nothing in customOriginally Posted by tgpo
I wonder if it matters that I'm using PAL settings?
Whether I copy them there manually or use 'Import' from within DVDSP2 the templates are in the right place at /Root volume::/Library/Application Support/DVD Studio Pro/Templates
I'm using DVDSP 2.03, I notice there is an update to 2.04 which fixes some obscure PAL issues ... guess I'll give it a try. -
no,live type is custom made for doing animated nemu's,pshop is completely different soft.
Photoshop is for static menus. LiveType can be used to create motion menus.
Livetype tot DVDSP help
By whiff79 in forum MacReplies: 3Last Post: 14th Mar 2010, 10:23
