  1. Hi, I have several mpeg2 files which are squishy in media player but play normal in ATI Multimedia center, so i thought they were alright. Anyway, I imported them into premier pro, edited it, then saved it as mpeg2 again. However, the end result played the those particular files squishy again even in ATI Multimedia center. Does anyone know how to fix this? or do you need more information?
    pic.
    <- why isnt picture working?
    Thanks,
    Three_Eleven.
  2. Anyone help me at all?
    Aug 2003
    Three_Eleven, "squishy" isn't very descriptive. I think you need to be more specific. You may want to consider posting in the Adobe forum where there are more AdobePro experts than here.
  4. Hard to say what is going on there. I guess it would be good to have some more info;
    Where did your original MPEG2s come from?
    Did you create them or get them "as is"?
    Do you know what screen format the originals were set for PAL or NTSC?
    Is original cropped or cut different than 720x480?
    What changes did you make in Premiere?
    What were your settings when creating another MPEG2 from PPro?
    Where are you planning on watching the finished product? TV, Computer?
    The more info you can give the better.
  5. Originally Posted by spmc
    Where did your original MPEG2s come from? -> Captured from ATI TV using MPEG2.
    Did you create them or get them "as is"? -> create
    Do you know what screen format the originals were set for PAL or NTSC? -> PAL
    Is original cropped or cut different than 720x480? -> not sure.
    What changes did you make in Premiere? -> Nothin pretty sure.
    Where are you planning on watching the finished product? TV, Computer? Writing to DVD to play on DVD player on TV.
    Here is pic to help.
    See how the lion dosent fill up all the preview screen? but it plays normal in ATI FIle player. I need to make it fill up the full screen in premier so it encodes it as full screen thanks.
  6. The screen shot is nice, but I can't tell what your PPro settings are. My guess is that your original MPEG2s are not the same format size as the settings you have established in premiere and premiere is trying to stretch or squish them to fit the PPro format. You are set up for PAL. I use NTSC so I am not going to be much help with PAL settings.
    Have you actually output to a final product to see how it really looks. Often times things look different in the preview window than they do in the final product.
