Hi,
I was trying to shrink the file size of a my dvd Terminator 2. I used DVD shrink but this only managed to compress it to 5.6GB. I removed all other other features not necessary such as different languages etc but only managed to cut it to 5.3GB. Now the file is still to big to fit onto a DVDR.
Any advice on how to cut it further would be much appreciated
Thanking you in advance
Stan 8)
4Million and a Penney
Rather Dead Than Not Red!!! -
When DVD Shrink doesn't work I revert to DVD Decryptor to rip to HDD then DVD2one to shrink it down to DVD5 sizing. Between the two options I haven't found a DVD I can't process.
Artificial intelligence is no match for natural stupidity. -
krco, did you try to make a movie-only backup using the "Re-author" mode?
In any case, a workaround is to shrink the "shrunk" files (shrinking twice).
That's a 9GB DVD9. The only way to do it is 'Movie Only' in Re-Author mode. Extras and menus don't get compressed very much in shrink. Alternately do the extras and menu as stills, but stil it's a lot of compression for the main movie. Trim the credits and intro, it helps.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Double shrink is actually not all that bad. I done it on a lot vid's that normal shrink wouldnt compress enuf to fit. I use a a 53" hidef tv and the pics is more then acceptable (as long as u dont do side/side comparision with orginal). Most pple couldnt tell that they werent watching an original.Originally Posted by ddlooping
Sometimes when DVDshrink cant compress enuf, I use CloneDVD and it seems to do the compression enuf so it fits. If that doesnt work then I double shrink. By doing double shrink and some re-authoring, I been able to put each of the Lord of the Rings Extended Edition DVD's (2 disk per movie, 3-4 hours each) on one DVD+R each (lazy, dont like getting up to put in second disk
thanks guys i have managed to do cut the file size big enough to fit onto one dvdr.
Krco 8)4Million and a Penney
"thanks guys"
You're welcome.
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 23:03 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 09:14 -
What to do when DVD shrink does not shrink enough
By Firewire60 in forum Video ConversionReplies: 4Last Post: 24th Sep 2007, 00:07 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 18:59 -
DVD wont shrink enough using DVD shrink?
By fazeshot in forum Newbie / General discussionsReplies: 4Last Post: 6th Aug 2007, 22:31
