hi aLL! b4 i use to do 1hour avi home videos and covert it to mpeg for burning as xvcd and took only 2 to 3hours... not that long... nway..
i use my laptop... 1.6 P4, 256ddr, 20gig...
my brother downloaded this cartoon movie from kazaa... its like almost two hours.. and the file in avi is 180mb and so i thought it would'nt take long... but then.. when i waked up n da morning it was still doing it! its was 56% already and it would be a waste to stop it.. so i just left it alone..now its finally finished! after 20hours! now the avi file that was 180mb is now 800something... is this normal?
cuz b4 my avi home video was bigger than it was when converted to mpeg.
thanks.
be careful talkin about p2p apps like kazaa(possible warez)
just given ya the heads up dude, some ppl will jump on ya if u say the wrong stuff
josh -
ohhh ya i totally 4 got bout that! thanks, but i guess its too late now.. i cant edit it... nway i wasn't think'n i was juz bout tu burn it to vcd and i found out the file was 810mb! its too big for a 700mb cd! grrrr!!!!
That does sound like a long time for the conversion.
As for filesize, all that matters is the length of the video, and the bitrate (i.e. how compressed the file is).
MPEG files may be more, or less, compressed than an avi file - it just depends on what bitrate is used.
avi's are typically more compressed than mpg files (because codecs like DivX etc.. work with higher compression than MPEG-1 and -2), but this isn't always the case. You can't generalise about it really.
cheers,
mcdruid.
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 14:11 -
new Virtualdub MPEG - still a colorspace problem with MPEG-&
By sanlyn in forum EditingReplies: 6Last Post: 10th Aug 2009, 22:18 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 07:30 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36 -
DGIndexed MPEG or AVI wrapped MPEG best for AVISynth?
By flywitness in forum EditingReplies: 1Last Post: 12th Sep 2008, 09:08
