Just acquired both the Asus TV FM Tuner and the WinFast 2000XP to make comparisons on AVI Huffyuv captures at full size and also compare quality qith the Canopus ADVC-100.
I conducted some very interesting tests (Using composite, S-Video for all 3) and I'll probably post some of the screengrabs if people are intersted to see the results.
However, on both the Winfast and Asus cards I got some weird scan lines (not even a full line actually) that was somehow 'shifted'. This is not due to a source problem (VHS in this case, but DVD grab had same problem), and the ADVC did not produce that artifact. Check the screengrab below (detail, not full frame).
http://www.workinggraphics.com/screengrab.html
Interesting thing is that this 'half scan-line' in the middle is not even from the same frame where it appears. Not a big deal if this happened once every minute but this is every 10 frames or so...
Anyone has a clue or had the same problem? Couldnt find anything on this anywhere...
Results 1 to 1 of 1
Reducing/eliminating scan lines?
By Captain Satellite in forum Video ConversionReplies: 9Last Post: 23rd Nov 2011, 06:37 -
Scan lines in the rip.....any help would be good
By Spinal_Core in forum DVD RippingReplies: 11Last Post: 27th Aug 2011, 12:57 -
Video Scan Lines
By sunnah in forum Newbie / General discussionsReplies: 7Last Post: 10th May 2011, 20:05 -
Progressive = Drags; Interlaced = Scan Lines. What's wrong?
By Taeran in forum Video ConversionReplies: 0Last Post: 27th Sep 2008, 08:40 -
ASUS TV Tuner problem with Video in & audio adaptor
By Zpazt in forum Capturing and VCRReplies: 0Last Post: 16th Jul 2008, 14:30
